Ok its done,my Sat. Alt. has 2 small wires on the plug that plugs into the Sat. alt..
The one closest to the engine block I think it was marked PLT or something?Goes to the .V.R. plug.
It has to go into 2 of the wires on the VR harness.the ones on the end next to each other.
I just did this with the car running ,and checking different combinations till,the dash lights went off.
The other small wire on the Sat. Alt. plug is left unhooked.Any one wire power hookup GM alternator should work.
Brake light functions properly.
Whit-- N.Y.
