vibmx wrote:no you can run it your internally or externally regulated.
If your car is internally regulated, chop the wires and splice in the new alt (wiring properly of course)
But if your car is externally regulated, you need to find your regulator, and by pass it, weather you cut the wires from both sides and splice them together, or remove it all and rewire, is up to you..
Now for a question that hasnt been answered 5 times allready..
Did we find a solution to the charge light on internally regulated models? If the wiring diagram gives it away forgive, im no good at reading them
if you look at the old plug while connected to the original alternator the terminal is marked "L" for light. this wire should be Yellow or White/Yellow on most older Toyota's. and is usually Brown/white on some(not all) of the saturn alternators.
As far as this Link
http://forums.club4ag.com/zerothread?id=71763 with the stupidly overbuilt heim adjuster bracket... I errantly forgot to tighten my adjuster bracket after replacing a bad saturn alternator in my TE 3 or so years ago and was in a pinch stranded at the race track. so I went to ace hardware and bought this in hopes of making it home
http://www.acehardwareoutlet.com/Produc ... ?SKU=58399 all stainless including the turnbuckle
I added a 3/16" right hand nut to lock one of the eyes and relieve some tension on one side of the threads and have not had any problems years later. I was astonished because they are only rated to 70 lbs which seemed flimsy for a tensioner bracket.
