Where is your ECU?
Here's where you post efi and turbo conversions, configurations, and questions related.
Moderators: Sunray, PERTANO, BOBLOOK
Where is your ECU?
Postby UtahSleeper on Fri Aug 05, 2011 10:34 am
So, I am trying to figure out the best spot to mount my MS2. Where does everyone else have thier ECU's mounted for the EFI?
80 Corolla Hatchback - Power (In Progress) http://www.3tcgarage.com/viewtopic.php?f=23&t=3208
88 Alltrac - Snow fun (Waiting) http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=43482
UtahSleeper
Veteran
Re: Where is your ECU?
Postby J-M Kujala on Fri Aug 05, 2011 2:11 pm
mine megasquirt is mounted under dash, to the passenger side, can see those couple leds and easy to connect lap top.
relays etc are under the hood, not yet finally installed, but they are going at own aluminium box, now mine is like in a test sessio :lol:
Carina TA-12 -72 3T
Celica ta-22 -74 2TG Turbo
Camry -93 3VZ-FE
Image Image
J-M Kujala
Lego Maniac
Postby te72rally on Fri Aug 05, 2011 2:53 pm
my sds EM4f is under the dash on the driver side, must keep it out of the engine compartment, rubber mounted or some other way to isolate vibration is good too
te72rally
Contributor
Postby alena on Sat Aug 27, 2011 2:31 am
I got a te72 with a 10pt roll cage thinking about msd and ecu ( Big Stuff) under passenger dash just gotta fabricate a plate for the electronic. also easy access and semi hidden, Aloha Mark
alena
Veteran
Postby Fera on Mon Apr 23, 2012 6:32 am
this is my ecu location
TA40
2T EFI TwinTurbo Engine
Ready
From Argentina
Fera
Contributor
Postby oldeskewltoy on Thu Apr 26, 2012 4:00 pm
Upside down... under the duct work
2 coarse screws up through the square mount of the duct, and one into plumber strap hung from a higher body mount
the small box hanging in front is the mini USB hook-up for my lap top
Information is POWER.... Learn the FACTS!
http://www.toyodiy.com/parts/ USE IT!!!!
oldeskewltoy
Lego Maniac
Location: Portland Oregon... the I see dead people neighborhood
Postby BOBLOOK on Fri Apr 27, 2012 12:06 pm
oldeskewltoy wrote:
which ECU brand is this
__________________________________________
JUN TECHNOLOGY
The Day We Learn To Think
Site Admin
