causes of fouled plug
- 781masshole3tc
ive recently tuned up my 1980 3tc with cap, rotor, wires, plugs (ngk gapped at .044) pcv, pcv grommet, fuel filter, air filter. The #1 plug is carbon fouled but the rest are normal looking, as mentioned in another post that i have square style ignition coil and another member says they are notorious for weak/failure. would a weak coil cause #1 plug to foul? (the plug is not wet, its a dry carbon foul) or would the distributer pickup assembly inside cause this. Its so weird i can have the car running like a champ for a day or two then run like total crap ola the rest, would the Aisan douchebag carb be also the culprit, im so in love with this old school car that it makes me wanna puke lol. (food for thought this car never ever smokes out the exhaust "no black no blue no white".
Re: causes of fouled plug
To tell you weigher is mechanical or electrical issue causing the fouled
You need to swap the #1 sparkplug and wire to the #2 cyl.
Then run it for a while then recheck it
If problem swap to cyl #2 then the problem is electrical
If #1 remain the same you need to look at a mechanical failure
What did you change already ? Dizz cap crack ed??
- 781masshole3tc
the #1 fouled plug was changed with the recent tune up a few days ago, up till know its sputtering while running so i assumed it was fouled out again, i was wrong, i pulled all the plugs and they are in great shape, i swapped back to the old wires and cap and it still sputtered, i punched (hit, wacked) the square ignition coil 3 times and the car stalled out on me, hmmmmmm this sounds like the coil is crapping out on me, Ebay has a replacement one for $11.05 new/shipped. im going to get it just so i can run the car in the yard and eventually save up for something nicer MSD/ACCEL etc. when i do up grade out of this square model do i eliminate the igniter/module that the coil mounts to or does it get integrated in with the new setup?
I dont think its the coil. Usually total failure, no spark. If it was weak, would be equal on all cylinders.
Whats the mileage? Might need a valve job.
Vacuum leak, could be a lot of things, just speculating.
Compression test can tell you about the motor.
Can you post a link to what you are going to buy for $11. Sounds too cheap to be worthwhile. I know its not much but no sense throwing away money.
Your coil is integrated with the ignitor. You need another from 81/82 or an MSD or there are posts for cheap HEI type ignitions. Do a search.
I won't bother simple get an msd box and coil for cheap and your done !
- 781masshole3tc
lets start off with Thankyou everybody who responded, this is the update, no more fouled #1 plug (it was a broken wire) all plugs are clean and distributor cap and ignition rotor are new also new ignition wires, the car runs ruff (sputters) as if there was a bad wire or plug, but there is not, so i PUNCHED the igniton coil pack 3 times and the car got mad at me and stalled, so the coil is probably getting weak and getting ready to die, so i just bought my $11.07 with free shipping a square igniton coil on Ebay lol, remember this car is my driveway queen for a little bit, and eventually i will replace some of the parts with better ones once i have the funds to do it. but as of now im learning about this old school car.
- 781masshole3tc
dont own a compression tester and dont have the funds to rent one yet. but will be considered to be done in very close future though.Toyota1515 wrote:Do a simple compression test buddy!
- 781masshole3tc
73te27 wrote:I dont think its the coil. Usually total failure, no spark. If it was weak, would be equal on all cylinders.
all plugs are clean and gapped at .044, i believe a week coil, car has 98k miles original, car does not smoke so i dont believe it needs a valve job but i would not overrule that thought, the sputtering just happened after replacing the cap, rotor, plugs, wires. so i put the original ones back in and it did not help, im really leaning towards the thought of the coil going caputs especially when i beat it up and the car stalled in fear lol
