Is my engine crooked/slanted
Is my engine crooked? Or is it cause its new engine and trannmounts
Re: Is my engine crooked/slanted
Use the 2t motor mounts.
It has the 2t mounts.... Brackets and mounts. To me it seems slanted. Im trying to find
Pics of TE27/21/28 with 2tc or 3tc....
Is the bottom of your sump level?
If the bottom of your sump is level & your carb is level then your engine is on a slant!
- toyotero2dend
All these engines sit a bit slanted unless you get solid mounts and straighten it a lil.Look at mine slanted too..
Thanks everyone for the reply,
thanks toyotero2dend for the pic... I was starting to think something was wrong......
- toyotero2dend
If still you see it's too slanted check the engine cross member that when you dropped the engine you didn't check down there and it's lifted on the right side
- oldeskewltoy
4AGs slant that way because the 1st gen 4AGE head oil drains were located on the D/S of the head... and hench a small lean. I do not know if the same is true (head oil drains) for the T
Yeah its to slanted, I shimmed it on drivers side and it sits perfect. I think its the engine bracket on that side.
its for a 2tc, but I dont think it is for a 71-74 corolla.
does anyone have a pic of the engine brackets on a TE27/28/21?
All 2tc motor mounts are the same.
