oops. piston out...wrong end
skabrock5
Post by skabrock5 » Thu Jul 10, 2014 5:50 pm
I was undressing my block and pulled a piston out the bore from the bottom hahahha bruto. any ideas on squeezing in the rings to get the piston back up and out from the top? where's "el chapulin Colorado" when you need him?
toyotero2dend
Re: oops. piston out...wrong end
Post by toyotero2dend » Thu Jul 10, 2014 11:46 pm
Go to autozone and rent the piston ring compressor tool
73te27
Post by 73te27 » Fri Jul 11, 2014 4:01 am
Seen it done before and the guy ended up throwing the engine away. A regular piston ring tool wont work unless you shorten it and it still will be a bitch to do. I think you have to try and remove or crack the rings.
skabrock5
Post by skabrock5 » Fri Jul 11, 2014 4:58 am
Man I was afraid of that. I can barely get my fingers around the main arches. Ill see what I can come up with.
skabrock5
Post by skabrock5 » Sat Jul 12, 2014 6:02 pm
skabrock5
Post by skabrock5 » Sat Jul 12, 2014 6:04 pm
Got it out with those three little tools on the left.
73te27
Post by 73te27 » Sat Jul 12, 2014 8:27 pm
Good one. The other one I seen the guy did all 4 cylinders.
