Is it true that if water goes in youre transmission(manual) it damage the gears??
Cause I have a 4ac transmission and it was in my yard and that day it has rain and the water went into the tail shaft in . Now I was cleaning the tranny I drain all that water with oil and then I was trying if the gears were good but it doesnt goes in any gears it stays in neutral
Now if that transmission needs a rebuild im not gonna do that I have another t50 onder my other sr but it is from the 2T engine , can I just put the bellhousing from the 4A and put the 22spline input shaft?? It's for swaping a 4age , any advise??
water in my tranny!
Re: water in my tranny!
Water won't harm the gears but the bearing !
Rebuild is expensive check for another one !
Damn man :s the t50 from the 4a is very hard to find on aruba you just find the t50 from the 2tc or 3tc , but can I put the bellhousing amd the 22spline inputshaft from the 4a t50 on the 2tc t50???BOBLOOK wrote:Water won't harm the gears but the bearing !
I dont see why not t50 is a t50 but there are different splines on them and bell housings change but thats all
Thxn bro!hemilove wrote:I dont see why not t50 is a t50 but there are different splines on them and bell housings change but thats all
I'm going to disasembled both of them and put the 22spline on the one im using and the bellhousing to
