Coil on plug VS MSD with distributor.
What would be better set up for street modified 3tc with a 296 cam and race double valve spring and ported head. MSD 6A with 10mm spark plugs and maybe a locked distributor if thats a smart idea? or coil on plug ?
Corolla Kid
トヨタ
トヨタ
Re: Coil on plug VS MSD with distributor.
Turbo or Na ?
MSD 6A with 10mm spark plugs The MSD6AL is better do the rev limiter
If Na no need for distributor locking
Msd al the way
After you install turbo you lock the dizzy
Why not COP? Im planning to use yaris (1nz-fe) coils on mine.BOBLOOK wrote:Msd al the way
Is because they are more tricky to make them work as the ECU trigger those smart coil packs they don't have separate control module.Heiska wrote:BOBLOOK wrote:
Even so if you installed them with an crankangle censor how do your gone trigger them ? How do you gone determine the coil charge time and duration dwell ?
MS2 or ms3BOBLOOK wrote:Is because they are more tricky to make them work as the ECU trigger those smart coil packs they don't have separate control module.Heiska wrote:BOBLOOK wrote:
Megasguirt ?Heiska wrote:
MS2 or ms3
But they would work on a waste spark system same trigger point right
