as the title suggests I completed a t50 manual transmission swap in my 81 corolla wagon, all components are in correctly, but the engine wont crank, i looped the bottom to top right wire that comes out of the old auto tranny to loop the neutral safety and i checked all wires going to the starter, but it still wont crank. any tips or ideas as to why it wont go. I have racked my brain and searched but to no avail.
help is appreciated, thank you
						3tc -> T50 manual swap car wont start
- deaconfrost
- Contact:
Re: 3tc -> T50 manual swap car wont start
You will have to bridge the neutral/park safety wire otherwise the voltage won't run to the starter . You can check on the diagram for the correct wire !
