2rz te21 stock cams
Re: 2rz te21 stock cams
BOBLOOK wrote:No parachute
its on order
Good luck did the race season already started near you ?
Thank youBOBLOOK wrote:Good luck did the race season already started near you ?
race season started in april
http://www.youtube.com/watch?v=0uhwe-KvPk8Richie2rz wrote:Thank youBOBLOOK wrote:Good luck did the race season already started near you ?
this was couple weeks ago slipping clutch time for a twin disc.
best run was 8.9 at 158 don't have a video of the run
The new dyno numbers 890hp 656 torque
Tires were slipping had to sit on the trunk and my son do the dyno pull lol
Your combo is working just perfect, did i hear some back fires at the top end or you are running out of gear?
yes it was running out of gear I changed the ratio since and had clutch problems till now have a twin disc will seeToyota1515 wrote:Your combo is working just perfect, did i hear some back fires at the top end or you are running out of gear?
