Page 2 of 2
Re: tranny expert question for T50
Posted: Fri Apr 03, 2015 8:32 pm
by toyorotor
Using the 1st one to the left in the pic. Bell housing is for the Big starter.
Posted: Wed Apr 08, 2015 6:05 pm
by tojo
Not so sure its just a clutch issue.. some Qs
Did forkshafts slide smoothly ? could they have been bent ? stick?
What oil are you using ? Is it just when its Cold or warm also ? have you driven it for a while ?
Posted: Wed Apr 08, 2015 7:50 pm
by toyorotor
tojo:
The Fork/shift rods Where not bent, but they where a little ruff...they came out of a Transmission that was water locked. I cleaned them up as much as I could....
Using Synthetic 85/140 I think....
Car has not been Driven, It just got put back together
Posted: Wed Apr 08, 2015 8:50 pm
by tojo
Id use a synthetic GL4 oil 75w-90 drive it and see if shifts improve. Mine did. Was a bit cranky when cold at first
but fine after about 1000km . Not as smooth to get in reverse as the newer style due to the "lift for R" but shifts fine now
Posted: Wed Apr 08, 2015 10:32 pm
by toyorotor
Ok ill try it....i just got the exhaust done so ill be able to go around block
Posted: Thu Apr 09, 2015 5:05 am
by tojo
Even tho I replied to the thread title I`m no expert or pro on the subject
Just going on opinion and a bit of experience
Good Luck
