Adding Gear Oil Through the Shifter?
Re: Adding Gear Oil Through the Shifter?
That's the part that pisses me off about the whole thing. I know I could do it, but I'm working with one set of hands. I listed it over the weekend on CL. Had a few bites but no takers yet.
The oil is still there same levelToyota1515 wrote:Actually the mazda can be filled by the shifter but it will take too long as the space for the thick fluid is very small.
LOL shit happens some times, is the gear oil to thick LOL
Did you try to put it in other gear to see if it goes down?
Nah try everything but maybe the turbo II is different from the sa '80Toyota1515 wrote:LOL shit happens some times, is the gear oil to thick LOL![]()
I use heavy duty high grade 80W/85W/140 rate
But i removed the plug in the side and use an small hose filled true the engine bay wait till it start came of and close the plug .
That was it, a couple more grades and it was pure grease, i did it with 75w90 GL5, and it went downBOBLOOK wrote:
I use heavy duty high grade 80W/85W/140 rate.
