A lot has been done. I have allot of pictures to pay will be up shortly.76Mustard wrote:Mike.. where the updates??? Thing is b-full Pa.mikealike wrote:there will be, ive been busy with building other stuff its crazy.slaus wrote:Any updates MIKE?
3sgte te72
Re: 3sgte te72
Re: 3sgte te72
I added this car to my Reyes Magos list
Re: 3sgte te72
Just alittle bit of work getting done on the rolla
this is the stock ae86 rear brakes, good for what they are but when it comes to stopping bigger is better.
Stock to upgrade, what do you think?
Just a small view. More to Come!!!!
Re: 3sgte te72
Front Brake upgraded, need stopping power on a budget, here you go!!!!
This is stock AE86, theyve been on the Rolla since Day one. They did the job but with the new power plant more is needed..
Comparision between the Rolla and my upgraded rotor.
You know that I like to make stuff happen on the low, here you go...
Re: 3sgte te72
small clip from along time ago... Enjoy
http://s378.photobucket.com/user/mikeal ... a.mp4.html
Re: 3sgte te72
What rotors are you using for the front and rears
Re: 3sgte te72
just depends on what calipers your going to use...Mazota TE51 wrote:What rotors are you using for the front and rears
Re: 3sgte te72
The question was what rotors are you using on YOUR setup... Are you using mini cooper front rotors drilled out or is it something else. You are saying you are doing brake upgrade on the cheap but give no info other than bigger caliper (fc) and larger rotors(?). btw. Looking Good
Civic and Cooper works well.
