Re: ignition coil pack wiring info needed for rpm tac
Posted: Mon Apr 14, 2014 7:55 pm
On the toyota if you see the diagram you can see the tach output (-) going true the igniter to the neg ciol
Welcome To The New Home of 3TC Follow Use On Social Media https://www.facebook.com/groups/3tcgarage/
http://www.3tcgarage.com/
80 is the only year with that oddball square coil. All the other years had the round coil with the square silver box ignitor. Surprising yours is still working, those have the highest failure rate in my experience.781masshole3tc wrote:green not yellow, its the only thing coming out of the igniter that the coil is mounted to that is not being used, i looked all around this this and nothing says tac, the tachometer i bought is a mini blackfaced sunpro super tach 2, it did not come with instructions but i found it already online for this exact model of tach. i thought for sure i wouldve had this thing already hooked up and that all of you already did this mod lol.
this info is HUGE to me, i didnt know that, well the next question will be what to replace it with starting from cheap to not too expensive, this is going to be a totally stock engine. im a Ebayer so any info on this the purchase will be through them. thanks again73te27 wrote:80 is the only year with that oddball square coil. All the other years had the round coil with the square silver box ignitor. Surprising yours is still working, those have the highest failure rate in my experience.781masshole3tc wrote:green not yellow, its the only thing coming out of the igniter that the coil is mounted to that is not being used, i looked all around this this and nothing says tac, the tachometer i bought is a mini blackfaced sunpro super tach 2, it did not come with instructions but i found it already online for this exact model of tach. i thought for sure i wouldve had this thing already hooked up and that all of you already did this mod lol.
Odd, I have a Jan-80 wagon and it's got the round one with the silver box, and as far as I can tell it came stock that way. Now I don't know if this is relevant in the slightest, but when I hooked my aftermarket Nippon Denso tach up, I just crimped eyelets onto the end of my wires, and attached them directly to the positive and negative posts on my coil, worked like a charm. Also, I have factory wiring diagrams from Toyota if you need them, I don't think I can scan them, but I could try and take good pictures or something.73te27 wrote:781masshole3tc wrote:80 is the only year with that oddball square coil. All the other years had the round coil with the square silver box ignitor. Surprising yours is still working, those have the highest failure rate in my experience.
