rear parking lights dont work
Posted: Mon Apr 14, 2014 3:50 am
by 781masshole3tc
hello, my rear parking lights and rear quarter panel marker lights dont work, (brake lights work, directionals work, reverse lights work) bulbs are good and properly installed (2057 and 194) just no power to the rear section of the parking lights, i dont see any fuses that control them. what else should i be checking? thanks
Re: rear parking lights dont work
Posted: Mon Apr 14, 2014 10:53 am
by mikealike
http://www.toyotamcdonoughparts.com/
they have the wiring diagrams for the circuits...
Posted: Mon Apr 14, 2014 10:42 pm
by 73te27
TE72?
Rust under windshield driver bottom corner?
If yes to both then most likely burnt trace in fuse box. Happen to me personally 4 times. I see others with this problem all the time. Dont know why buts its always the parking light circuit. First click on the combo switch. You can change the fuse box but will burn again if water keeps dripping. Happen to me also. I hardwire and bypass burnt trace.
Posted: Wed Apr 16, 2014 12:02 am
by 781masshole3tc
73te27 wrote:TE72?
yes there is rust there and im going to attack this fuse box, have you Siliconed anything to make this stop? is this mounted behind that plastic kick panel where there the speaker is on driver side? (hopefully) nice and low for easy removal. thanks
Posted: Wed Apr 16, 2014 2:12 am
by 73te27
Honestly dont know how to stop the leak.
Drivers side kick panel. The fix involves hard wiring the flasher so it dangles from the box but I forget exactly how I did it, been a while maybe 8 years since I did it last.
Usually hard wire repair lasts longer then replacing fuse box.
Posted: Wed Apr 16, 2014 2:33 pm
by 781masshole3tc
thankyou, i will focus on the fuse box next, sounds about right with the rust gathering in that corner.
Posted: Thu Jul 17, 2014 7:03 am
by 3trolla79
Mike alike u are the man! For that link website!
Posted: Tue Jul 22, 2014 12:51 am
by baldo
^^^ WOW!!! Have been looking for something like that for a long time. How long did it take you to find that?
I know where my next check is going!
