My 73 KE26
My 73 KE26
Hey Guys,
Just joined up here so i figured i would post up my ride... Its a 73 Ke26 corolla with a 13b turbo, jatco 3spd Auto and a hilux diff... Here are some pics from where it started, to where it is now
First started Racing it, it went 12.0 115mph on a stock 13b with the auto and a bad converter..
Pulled the car all down, got the motor all built, box freshened up, better converter. To date the car has gone 11.64 124mph spinning off the line.. Should see a low 10 once i get traction .
<iframe width="560" height="315" src="//www.youtube.com/embed/412Gmke9TOg" frameborder="0" allowfullscreen></iframe>
Re: My 73 KE26
Sweet looking 4dr KE26.....very nice. Was it hard to make the Tunnel?
Re: My 73 KE26
Tunnel was quite easy to make..toyorotor wrote:Sweet looking 4dr KE26.....very nice. Was it hard to make the Tunnel?
toyotero2dend wrote:Very nice wagon I didn't know they came in 4 doors,Keep up the good work
Im from Australia, the 4 door wagons are more common then the 2 door panelvans, there are only a handful of them out hereBOBLOOK wrote:very nice 4 doors wagon welcome to on the forum
Cheers for the comments guys
Re: My 73 KE26
did you fix the traction issue ?13bke26 wrote:Yep that's it
Re: My 73 KE26
Yeah mate the issue on that run was that the tyre pressures were a bit high and the fact that I let the transbrake go at around 8000rpm... And that was my last run out... Next time out I'll lower the pressures and set up a 2 step on the transbrake..
Re: My 73 KE26
Cool keep us updated i had plan to install an 13b rew in the corolla but i quit that idea now all the stuff will be swap in the Rx7 sa
