Dummy distributor
Dummy distributor
Looking to put a crank trigger wheel in use, what's the best option for the distributor. I was thinking take the rotor cap off with the trigger and using a cut off wheel , cut it flush and make a cover plate to go where the cap was. The shaft is locked in place so it can still turn the oil pump. Right? Thanks in advanced!
Re: Dummy distributor
Assuming you will be using waste spark that should work well!
I have created a cam sync sensor with mine but cannot yet confirm its success as I have not yet reached fire up stage...
It would work Jason as long as it is indexed ti the #1 it will work.NME308 wrote:Assuming you will be using waste spark that should work well!
Cool, thanks ! Boblook what kind of fab skills did it take to make? Pretty easy?
Thats not my Art so can't tell you build is Sunray ( previous board moderator) hope he is fine ?
I would pickup an old dizzy and start improvising sometime you handier then you expect
Datzilla wrote:Cool, thanks ! Boblook what kind of fab skills did it take to make? Pretty easy?
I'm on it, if I had a full set of tools I could be dangerous! Haha!
Datzilla wrote:I'm on it, if I had a full set of tools I could be dangerous! Haha!
