fuse blows out every time i turn the key toyota te37
when i put in a new fuse for the wipers/turn signals the fuse keeps blowing out its been like this every since i had an alarm installed my 76 corolla
corolla lifestyle
Re: fuse blows out every time i turn the key toyota te37
Means the alarm is causing the fuse to blow ??
some one told me that it could be bad ground because the car had an old alarm before
corolla lifestyle
Bad ground wont blow the fuse. Drawing too many amps or direct short. Sounds like direct short. Double check your alarm connections.
its weird to when i hit a pot hole or a bump the alarm goes off for like a second would i have to disconnect it?
corolla lifestyle
Disconnect the alarm power 12v + source to checkchris76corolla wrote:its weird to when i hit a pot hole or a bump the alarm goes off for like a second would i have to disconnect it?
If the alarm is connected to the lights you might want to check there. One might be blown or there is a bad connection to them blowing the fuse. I would go through the wiring again.
well i tried disconnecting the alarm trying it like that fuse still blows out
corolla lifestyle
The alarm is pulling to many amps for that fuse and then it blows right ? So what you should do is run the alarm through a bigger fuse or add a fuse just for the alarm.
Corolla Kid
トヨタ
トヨタ
yea the fuse is for the turn signals and windshield wipers everytime i put a fuse in it would work for a little then itll just blow out or when i turn the key how would i run it on its own fuse
corolla lifestyle
