TE21/S2000 Swap
Re: TE21 build in progress
Cleaned up the rust on the pedal box... my master cylinder from Jegs did not arrive as expected. I called and they gave me a $10 gift certificate toward my next purchase
According to the tracking it should arrive today. I'll get a few coats of paint on my pedal box and start mocking it up this eve.
Found a pic to keep myself motivated. This is a tough project...
Re: TE21/S2000 Swap
looking good! sent u a pm question on the rear end.
Re: TE21/S2000 Swap
Looking good...great work so far...aren't you going to have to shorten that GTS rear end?
Re: TE21/S2000 Swap
hi sir ,are you a Filipino by descent?
Re: TE21/S2000 Swap
Max, text me when you can.maxdout wrote:looking good! sent u a pm question on the rear end.
Thank you sir!gotae86 wrote:Well done sir!
After calculating the cost of narrowing the rear end, I've decided that I'll just run flares.toyorotor wrote:Looking good...great work so far...aren't you going to have to shorten that GTS rear end?
Yessir i'm Filipinored888 wrote:hi sir ,are you a Filipino by descent?
Re: TE21/S2000 Swap
That is a great swap!!!!
Re: TE21/S2000 Swap
Hi Guys, I haven't updated in a while because I ended up buying my friends Peanut with the F20c swap already in it. I've buttoned up a few things on the new peanut so that I can daily drive it so I can now turn my attention back to finishing my build. I have the Crossmember reinforced now and am planning to drop the motor back in. Once it's in, I'll need:
1) finish the transmission mount
2) driveshaft
3) brakelines
4) coolant lines and pick a radiator
5) wiring
The crossmember clearance is tight so this isn't the prettiest but it's strong and should to the trick.
2) driveshaft
3) brakelines
5) wiring
