Page 6 of 8
Re: TE21/S2000 Swap
Posted: Mon Apr 27, 2015 3:17 pm
by Rolap7
maxdout wrote:Rolap,
so which cable did you end up using for the front cable.
For both of my peanuts with AE86 rear ends, the Celica front Cable is what fit perfectly. The TE21 cable was too short, the AE86 cable was too long. For the rear cables, I'm using two of the same side from the AE86. I can't remember if it's driver or passenger but the part number is BC93880 from Brake Best.
Re: TE21/S2000 Swap
Posted: Sun May 03, 2015 7:38 pm
by whit
Re: TE21/S2000 Swap
Posted: Mon May 04, 2015 4:17 pm
by Rolap7
awesome! thanks for sharing the info
I may use that in the future on other projects.
Re: TE21/S2000 Swap
Posted: Sat May 30, 2015 11:54 pm
by exodus
that's my buddy jeff's peanut!
i sold him those stretched steelies!
im glad the car went to a good owner!!
Re: TE21/S2000 Swap
Posted: Sun May 31, 2015 12:59 pm
by Rolap7
exodus wrote:that's my buddy jeff's peanut!
Thank you sir!
Re: TE21/S2000 Swap
Posted: Tue Jun 23, 2015 5:07 pm
by Rolap7
Re: TE21/S2000 Swap
Posted: Mon Jul 13, 2015 1:02 am
by spiceisler
Looks original. Great job!
Re: TE21/S2000 Swap
Posted: Sat Aug 22, 2015 4:39 am
by bryanhernandez3727
Which starlet steering column did you use or got parts from.
Re: TE21/S2000 Swap
Posted: Thu Sep 03, 2015 6:16 pm
by Rolap7
Hi Bryan, I'm not sure which year but the chassis code is KP61. Hope it helps.
Re: TE21/S2000 Swap
Posted: Thu Sep 03, 2015 10:23 pm
Rolap7 wrote:Hi Bryan, I'm not sure which year but the chassis code is KP61. Hope it helps.
Thank you every bit of info helps.
