hi,
anyone have the NGK part number for the plug wires. NGK website listed same as 2T/3T, aren't the connectors longer for those engine
compared to the 2tg?
2tg NGK spark plug wires
Re: 2tg NGK spark plug wires
old post but oh well..
2t/3t leads can work on a 2tg but the lengths and rubber plugs are not the same. dohc heads have the leads come out at 90degrees whereas ohc heads are vertical.
90 degree rubbers can be tidy looking like this.
vertical leads can also look good once the lengths are corrected.
I bought a roll of 8mm plug wire and just make my own and reuse the rubber boots for the new set. it was a cost effective way to change the plugwires good luck
Greg
Greg
its a TA 27 not a TE 27
