2tc fuel injection options?
From what I hear the 2tc and 3tc have pretty similar head, I want to know what I need to convert to fuel injection. What efi Toyota stuff is compatible with the 2tc engine?
Re: 2tc fuel injection options?
If you think the biggest problem is to figure out what head to use with efi, you really need to get more info about the set up and how it works. What do you need to convert to fuel injection? Full custom set up everything. What efi stuff is compatible with 2tc or 3tc head? 3teu intake. I think you can use 3tgte intake with a custom adapter.
You want to know everything you need to go efi or what Toyota parts you can use?
You can score an cheap ECU and get in intake plenum and get it to work find
Those 3teu aren't cheap
