				bike carbs on 3tc
				Posted: Mon Apr 13, 2015 4:32 pm
				by rollakid
				So I'm doing a bike carb conversion on my 3tc and im just looking for some input and help on how to run the lines and all that good stuff any help is welcome
Or if there's a wright up somewhere I'll welcome that as well
				Re: bike carbs on 3tc
				Posted: Wed Apr 15, 2015 1:28 pm
				by NME308
				Hi there mate,
Hemilove and 78sleeper on these forums appear to have been down the motorcycle carbs route with success so I would suggest look at the project gallery section for their ride threads and then hit them up for any extra info not visible!
				Posted: Wed Jun 17, 2015 11:13 pm
				by skunk1
				its not hard, you just have to have the manifold, there are pics of my setup in another thread here.  what carbs you trying to use?
				Posted: Fri Jun 19, 2015 6:01 pm
				by hemilove
				r1 carbs off a 1998 r1 with a dynojet kit stage 1 is good and a cheap ebay 3-5psi fuel pump with a knock off 1-5 fuel pressur regulator and a 0-10 fuel pressure gauge and a inline fuel filter with enough fuel line to the tank or you can tie to the fuel feed you will not have any fuel return so thats why the fuel pressure needs to be set at 3-4.5psi gravity feed pressure plus your manifold needs to be made and the linkage but thats not hard
