some who can tell me where the big difference between 3t and 13t engine is.
most intra criticized in about when is a difference in the block.
is Mother been offered a 13t engine (complete) and thinking about putting a 2tg cylinder head on the
3T vs 13T
Re: 3T vs 13T
Hi there mate,
The 13T engine has strange shaped pistons to match the strange pre-combustion chamber design in the head.
If you are installing a 2TG head at a bare minimum you want to carefully check piston to valve clearance. A set of regular 3TC pistons would be my first choice if you can get them but probably not essential.
Re: 3T vs 13T
the pistons from 2tg engine is not used. them I have for several sets and will be the easiest for me unless I go out and buy some new pistons
TE37 SR5 - 3TG +
AE86 - 9AGE +
240Z - RB25DE
AE86 - 9AGE +
240Z - RB25DE
Re: 3T vs 13T
The 13T pistons cannot be used if you are going to put on a 2TG, 3TGTE 2T or 3T head.
As Jason said, you will have to change out the 13T pistons!!!
- Spudenater
Re: 3T vs 13T
^That is what 13T pistons look like, as opposed to the symnetrical, domed/plateau'd pistons of the various 2T/3T motors. I was sold a shaved 13t head and these pistons as "high compression" 3TC gear before I realized what they were. It's not technically wrong, but certainly not what I was after. To reiterate what everyone else has said, 13T pistons will almost certainly not work with any other head because of the steep ramp causing valve clearance issues. That said, a 13t head may work with a 2T/3T variant set of pistons, though it will probably do weird things to compression and squish area...
