71 turbo RZ
Re: 71 turbo RZ
VEry good to know. Was your floor hammered at all to clear the bellhousing? Also what oil pan did you use? I have a2wd truck pan
Re: 71 turbo RZ
Yea you wanna use the 2wd pan, im using an r154 trans so i did have to massage a little but if you use the 2wd trans i dont think you have to massage if you do its only a little
Re: 71 turbo RZ
Are you going with the straight motor or stock lean
Re: 71 turbo RZ
Im going with whatever angle I can fit the motor in there the easiest haha. I have a LC supercharger bolted to the engine but I took it off due to the brake booster hitting it. Im using the 22r truck trans i think its a W55 with the 3rz bellhousing atached to it. Did you move your brake master? Also did you just notch the crossmember? Got any pics of the build? Thanks
Re: 71 turbo RZ
il get some up when I get a chance, on the brake master im using a wilwood one
Re: 71 turbo RZ
Nice! I actually just cut my crossmember yesterday almost exaclty where yours is cut. I do however still have the original steering set up and it now hits the pan. Im gonna see if I can set the motor right above it and see if the hood closes. Its so tight in there. If not I was thinking of using a rack set up as well. What kind of rack is that? Was thinking of using a newer corolla front wheel drive rack and hooking up the power steering. Is the wilwood master your using a dual master or a single?
Re: 71 turbo RZ
YeapBOBLOOK wrote:Starlet rack ?
Re: 71 turbo RZ
The wiwood is a single i just teed it to the line your stock steering will work just move the motor a little more up and you should be finechevyota84 wrote:Nice! I actually just cut my crossmember yesterday almost exaclty where yours is cut. I do however still have the original steering set up and it now hits the pan. Im gonna see if I can set the motor right above it and see if the hood closes. Its so tight in there. If not I was thinking of using a rack set up as well. What kind of rack is that? Was thinking of using a newer corolla front wheel drive rack and hooking up the power steering. Is the wilwood master your using a dual master or a single?
