3tc adapter for a tremec t5 trans
Does anyone know if there is such a thing?
For the price I rather use the tremec than a Toyota trans . Plus you can change all the gear ratios in the trans to suit what you need
D
D
Re: 3tc adapter for a tremec t5 trans
Am sure with the proper bell housing adapter it will work , 13b to tremec is possible as so 3TC
BOBLOOK wrote:Am sure with the proper bell housing adapter it will work , 13b to tremec is possible as so 3TC
man i been looking and asking people but no one knows.. or wants to share their knowledge
Well for what i now they use those W50 and W58. The W50 they use to install the jerico internals to make it even stronger.
After those blew the swap to clutch assistance transmissions or clutchless.
Check with G-force transmissions.They have a plate and machine a input shaft for a T-5 transmission
Grab a chuck of aluminum and start drilling holes.
Did you have to machine the input shaft down for the pilot bearing or what did you do for the pilot bearing?
