Josh 3TC turbo TE72 now!
This is a street build, i am doing for a friend, we are using as a R&D for Island Chain Racing 3T W58 Tranny adapter, we got a goal of 375 to 400 to the wheel on it, and it will have a Fueltech ECU setup, if you guys takke a close look to the engine block you can see is a very special block (3TGTE) that it has been worked out to work as a 3tc, So far this has being punched to 87mm, eagle rods and wiseco turbo pistons in block has being align honed and squared, 3TC cam bearings installed, 3TGTE HV oil pump installed, rings gaped and bearings measured to perfection plus Schneider Custom Profile Racing Cams installed, this will B interesting, stay tuned more updates soon!
Re: Josh 3TC turbo AE86
Head job done, now SS valves, bronze guides and valve job to b done soon to get this wrapped ASAP!
man i wouldve left 3tgte, but thats my opinion. Looks good!
hard to find parts expensive custom parts and a market that doesnt help, nahhh 3TC will do the same with way less!mikealike wrote:man i wouldve left 3tgte, but thats my opinion. Looks good!
Toyota1515 wrote:hard to find parts expensive custom parts and a market that doesnt help, nahhh 3TC will do the same with way less!mikealike wrote:man i wouldve left 3tgte, but thats my opinion. Looks good!
hit me up...
Looking forward to the finished product. What will you be using for the turbo?
Precision 62 62 tial 42mm WG and 50mm BOV 750cc RC injectors and Fueltech EFI system coil over plug setup!Mazota TE51 wrote:Looking forward to the finished product. What will you be using for the turbo?
