2tc turbo street legal Rail..
Well I have finally started throwing some money at this thing... My grandfather produced these kits in the 70s and this is on of the only known survivors.. We actually built the car in 91..
Turbo 2tc
Ray Jay snail
SU draw through setup
blow through valve.. no wastegate..
turbo corvair aircleaner
3tc ignition with no vacuum
type 1 trans (68 box) ..welded 3 and 4th ( needs more with more boost.. coming soon )
Plans
weld headlight brackets to beam..
Install front brakes along with a 67 master cylinder
source some 15x9 porsche fuchs for the rear and a 15x6 up front
Install tach..
thinking about going with a holley draw through setup with intercooler and wastegate
Love to source a used 3tc used moroso oil pan
Need to build a breather box
Would love to build a merged turbo manifold
Install some kind of boost retard box
better plug wires
Polish and power coat the crap out of things
Install 59 caddy tails..
ad electric fans for radiator.
Much more that i cant think of right now..
When we engine dyno'd the motor it made 210 crank.. the car weighs roughly 850.. Cant wait till its 300 crank ..Enjoy
Installed a adjustable beam and added drop spring plates the other day..
Turbo 2tc
Ray Jay snail
Plans
Install tach..
better plug wires
Re: 2tc turbo street legal Rail..
This is very nice, i would made the engine go the other way with the trany on the back, but that is just me, this thing is so nice!
Dang looks way different hammered like that. I like it..
- skellington
Woa. Talk about power to weight ratio. Get rid of that nasty camber on the rear and you can put it down to the ground.
1974 TE27 TWINS!
#2 viewtopic.php?f=27&t=2036
You know nothing about swing axle vw transmissions obviously.Lol
Tight work post a video
yea post a vid!!!
I think my buddy came and got a few parts off you, a set of turbos and manifolds.
I have one of your 3tc manifolds. the 3 bolt one though..
Wondering if if brakes end of the road vw brakes usually crap
Toyota1515 wrote:This got to be a blast to drive in the weekend!
