Gauge
Gauge
Hey guys where should I tap into,, to get the boost gauge to work on my blow through set up?? Lil confuse here don't know if I should tap into the intake mani or into the bonnet?? Was gonna do it between the turbo & the Boost knob but was reading that it does not give an accurate reading??
Re: Gauge
Got to be betwine the Carb/throttle body and head, on the intake manifold, one of the carb vacuum port will work just fine.toyotero2dend wrote:Hey guys where should I tap into,, to get the boost gauge to work on my blow through set up?? Lil confuse here don't know if I should tap into the intake mani or into the bonnet?? Was gonna do it between the turbo & the Boost knob but was reading that it does not give an accurate reading??
Re: Gauge
thanks alot for the info toyota there is a vaccum port on the carb. if not i will tee it to the bov hose thats coming out of the intake mani
