Page 1 of 2
shaving a 3tc head for more compression = hp
Posted: Sat Oct 26, 2013 11:27 pm
by hemilove
I would like to raise my compression on my hilux with a 3tc but how much is a good amount to shave off the head to get like 10:1 or 9.5:1 compression if yall have done this let me know bc these r1 carbs are pulling the air in but the engine cant keep up I want HP by just shaving the head and maybe a lil cam also
Re: shaving a 3tc head for more compression = hp
Posted: Sun Oct 27, 2013 5:48 am
More Compression needs more octane, and yes a cam helps a lot with a set of proper valve springs for it, Shaving the head could be done all the way down till you touch the max shave button on the head, and u can go like .50 over that, but remember to measure valve to piston clearance and as long as you got .100 of clearance you are A-OK. again remember compression and low octane fuels dont mix!
Posted: Sun Oct 27, 2013 8:50 am
by hemilove
Toyota1515 wrote:More Compression needs more octane, and yes a cam helps a lot with a set of proper valve springs for it, Shaving the head could be done all the way down till you touch the max shave button on the head, and u can go like .50 over that, but remember to measure valve to piston clearance and as long as you got .100 of clearance you are A-OK. again remember compression and low octane fuels dont mix!
yes sir but were am I on the safe side but higher on compression like at 10:1 or so bro like .30 or more
Posted: Sun Oct 27, 2013 11:25 pm
hemilove wrote: yes sir but were am I on the safe side but higher on compression like at 10:1 or so bro like .30 or more
choose a cam first and then let me know, a good safe cam will b a 284 AD by 476 lift or 494 lift, check Schneider cams as they have being very good to me and always accurate,
check the grind number 284F-HL
and then shave the head .50, then check the valve to piston for clearance and make sure is over .100 and add the single valve springs from ebay
http://www.ebay.com/itm/EMPI-4040-HIGH- ... db&vxp=mtr
and add the motorcycle carbs and you will be very happy man!
Posted: Mon Oct 28, 2013 2:02 am
by hemilove
Thank you sir for the suggestion and I will take that under concideration.
Posted: Tue Nov 12, 2013 12:14 am
by toyotero2dend
Carlos my friend had a rolla,the head was shaved , had header no cam just a carb out of an rx7 witch is 4 barrel you should see how that 3tc pulled and would start rite away even in winter,,, so I say head job and good Carb. & header is great for a cruiser ;)
Posted: Tue Nov 19, 2013 5:49 am
by hemilove
toyotero2dend wrote:Carlos my friend had a rolla,the head was shaved , had header no cam just a carb out of an rx7 witch is 4 barrel you should see how that 3tc pulled and would start rite away even in winter,,, so I say head job and good Carb. & header is great for a cruiser ;)
Bro my 3tc makes power and enogh to blow my transmission up so after that I said my truck is a cruiser not a hot rod no more t50"s are weak lol
Posted: Wed Apr 02, 2014 11:38 pm
by hemilove
how much is 50 thousands of an inch
Posted: Thu Apr 03, 2014 1:51 am
hemilove wrote:how much is 50 thousands of an inch
It is 50 out of a inch if you devide that inch in 1000 equal parts. so you got 950 of those left :lol: :lol: :lol:
Posted: Thu Apr 03, 2014 2:46 am
by hemilove
is that a lot of performance shaving power that I will notice toyota1515
