				4AC flywheel in a 3TC
				Posted: Mon Nov 18, 2013 2:32 am
				by CorollaSlammered
				The flywheel in my 3TC is an aftermarket flywheel and it is quite a bit bigger than the stock 4AC. With that being said it doesn't look like it will spline up with my starter cause it is not big enough in diameter. The stock 3tc flywheel should be 200mm in diameter and so should the 4ac... SO! Does it sound like I just need a 4AC starter or what could I do?
-the flywheel that is in my car is bigger than the stock 4AC flywheel.
-new starter?
Or
-3tc flywheel?
(Starter is cheaper)
				Re: 4AC flywheel in a 3TC
				Posted: Wed Nov 20, 2013 1:53 am
				by baldo
				Posted: Wed Nov 20, 2013 1:12 pm
				by toyotero2dend
				Maybe an 83 rolla with a 3tc engine , if so ? No The 4ac f/wheel can not be used
				Posted: Wed Nov 20, 2013 10:25 pm
				by NME308
				Hmmm...
Allow me to stir some mud in to the already unclear waters...
Maybe OP owns a corolla originally equipped with 4AC and T50 gearbox to suit?
Maybe the OP has made a good decision to replace the 4AC with a 3TC?
Maybe OP is hoping to bolt the 4AC T50 and its clutch/flywheel up to the 3TC?
3TC bellhousing bolt pattern is different to 4AC.
3TC flywheel bolt pattern on the crank is different to the 4AC.
As already indicated you need a gearbox and clutch and starter motor from a 3TC, or ones which are actually compatible!
Nope still no clearer???
				Posted: Thu Nov 21, 2013 9:48 am
				by corolllin
