81 corolla rear coilovers?
hemilove
Re: 81 corolla rear coilovers?
Post by hemilove »
so is there any cheap solution to our rear suspension
Fb rx7 mazda with ford 8.8 swap
hemilove
Post by hemilove »
BOBLOOK wrote:Fb rx7 mazda with ford 8.8 swap
what modle is the fb and is that just o coil no need to make a modifacation
fb is mazda rx7 yes modification is done rearend is not stock ford 8.8
Post by Heiska »
Vw polo 6N rear coil over is almost direct fit and cheap :D Full set of coilovers is around 200€ and you can use fronts too but takes little bit more work.
Is there any cheap adjustable rear suspensions, like that NTS or BRD racing.
UtahSleeper
Post by UtahSleeper »
May have found a DIY solution. Anyone happen to know the stock spring diameter?
Adjustable perch:
http://daymotorsports.com/proddisp.php? ... 5%22+or+5-
Spring:
http://daymotorsports.com/proddisp.php? ... +better+co
I imagine there are alot of other spring options out there, I have just been having a hard time finding something for adjusting. Turns out searching with the term coilover is not really useable when talking about the rear on our cars..
1980 Corolla
1988 Celica Alltrac
2013 FR-S
