Need help installing fuel pump
- Jmwboriocua
Hi guys, i am really close to finish my 80 wagon, but for some reason i cant figure out how to install the hoses in the fuel pump.
bubbajohnson
Re: Need help installing fuel pump
Aren't there arrows on the top of the pump showing inlet and outlet? There should be an inlet from the tank, outlet to the carb and a return line. The return line is a little smaller then the inlet and outlet. I don't have a stock pump anymore, or I'd go take a picture. Can anyone help this guy out?Jmwboriocua wrote:Hi guys, i am really close to finish my 80 wagon, but for some reason i cant figure out how to install the hoses in the fuel pump.
Well first thing first. Is it a stock pump?
- Jmwboriocua
It is a original pump, and it does not have any directinal arrows to guide by. I can figure out the return but what abur wich one are the othe two?
Install them if its not crank you switch them doesn't harm anything
Ok I just saw a picture. Im glad you said it had 3 lines.
So the line closer to the car is the "in" line and the one closer to the distributor is the out. Then the middle is return.
- Jmwboriocua
I will try it tomorow, hopefuly it woks.....
