OST-028: Redline it baby....
Re: OST-028: Redline it baby....
MUCH RESPECT! Your patience is inspiring. Keep up the good work!
"As the excellence of steel is strength, and the excellence of art is beauty, so the excellence of mankind is moral character." - A.W. Tozer
- oldeskewltoy
oldeskewltoy wrote: Well.... at least now... I can pull this out of the corner, dust off the past 4 months, and get this assembled....
Short gif... first view is half assembled, 2nd is fully assembled 3rd view is with lifter buckets installed.....
now all I'll need to do is fit the CORRECT shims, under my clients Poncams....
More to come.....
- oldeskewltoy
There is a Tomei Poncam, this one is indicated on the box and the cam itself as the intake cam... interesting that the dist drive gear is there.....
The client included all of his shim and bucket assemblies, remember those labelled parts?
I took each shim - carefully cleaned, then measured, then and put into my shim kit. The shims coming out were mostly 2.95mm and 3.00mm with a 2.9 and a 3.05 coming out as well. With freshly machined seats, and many "new" valves, I guessed that I should begin with 2.85mm shims to accommodate the seats and valves being cut.oldeskewltoy wrote:
Each bag contained a valve, a spring, a retainer, a spring seat, and 2 keepers, a lifter/bucket, and a shim.
Here are the initial measurements(intakes): measurements in inches.
"L" = loose, but not quite fitting the next size
"T" = tight, but not quite fitting the next size
1 - .011L
2 - .006T
3 - .008L
4 - .012
5 - .013T
6 - .009
7 - .006
8 - .012
So anyone remember Tomei Poncams intake clearance? How many of the valves need adjusting?
More to come......
- oldeskewltoy
Intake side set.... shim kit to right has well over 200 shims
most being 2.9, 2.95, and 3.0
This job is requiring a few thinner shims, I'll need to order 2 - 2.65mm shims, and 1 - 2.75mm shim...
about a week out.....
Anyone care to guess which valve I'm measuring, and what size feeler gauge I'm using??
more to come.......
I'm guessing exhaust valve 3 and 4. Using 0.3mm feeler gauge.oldeskewltoy wrote: Anyone care to guess which valve I'm measuring, and what size feeler gauge I'm using??
I finished my 4AGE build about a month ago and I'm working on two more heads as we speak.
g
- oldeskewltoy
gotae86 wrote:I'm guessing exhaust valve 3 and 4. Using 0.3mm feeler gauge.oldeskewltoy wrote: Anyone care to guess which valve I'm measuring, and what size feeler gauge I'm using??
I finished my 4AGE build about a month ago and I'm working on two more heads as we speak.![]()
g
The specs on the Tomei cams* is .20mm intake and .25mm exhaust - note no range, Tomei wants them as tight to .20, and .25 as they can be.
Tomei Cam card - http://ost.ebeans.ch/albums/userpics/10 ... l_file.jpg
exhaust valve #3, the gauge can be seen... and the exhaust side would be .010"(.25mm)
