te20 te27 te28 engine cross mem, motor mounts & steerin knuc
Re: te20 te27 te28 engine cross mem, motor mounts & steerin
Are u sure the carina arms ain't the same as te27. They are both original TExx cars...
Anyway, I was pretty sure they were the same
Sorry long time not reply. If you could take pictures of the arms and or measure the distance between the strut bolts and the pivot and control arm point that would be much appreciated.TPR Motorsports wrote:Are u sure the carina arms ain't the same as te27. They are both original TExx cars...
Bump I still need steering knuckles.
very much demand for te2 steering knuckles here in NZ
I believe the celica/carina knuckles have the larger 14mm ball joint like e3/e7/ae86. ta22 definitely do. whereas ke2/te2 corolla has 12mm ball joint, so te2 knuckles are handy for ae86 struts into ke2 chassis.
I'll get u pics this weekendmodify wrote:Bump I still need steering knuckles.
Did you manage to get any pictures?TPR Motorsports wrote:I'll get u pics this weekendmodify wrote:Bump I still need steering knuckles.
