Does this apply when installing a locked distributor?
Might seem dumb question to ask or obvious, but i don't have a clue about locked distributors and how to set the timing in turbo app. But i will be attempting to do so on my own with my 2TC.
So will this procedure per the Toyota Repair Manual still apply?
Re: Does this apply when installing a locked distributor?
Ok thanks.. and after that it's just a matter is turning the distributor accordingly to get the timing you want right?
read page 9slaus wrote:Ok thanks.. and after that it's just a matter is turning the distributor accordingly to get the timing you want right?
http://microtechefi.com/download/ltmanual.pdf
I did and i don't understand what page 9 had to do with this bro?BOBLOOK wrote:read page 9slaus wrote:Ok thanks.. and after that it's just a matter is turning the distributor accordingly to get the timing you want right?
It tell you how to set the timing ones you locked
What ignition system are you using ? if its an ECU with ignition control you can apply it as per page 9 !
I'm doing a blow through 32/36 weber and using an MSDBOBLOOK wrote:It tell you how to set the timing ones you locked
Which msd ? Btm or 6 serie with boost retard ?
6AL2.. was planning to just lock the distributor and don't do any boost retard. Can i do that?BOBLOOK wrote:Which msd ? Btm or 6 serie with boost retard ?
That really depent on the boost you want to run. like your idea won't have bottom end power
Here is an sample NOTE just an sample how it work so numbers are not correct
- Attachments
- Untitled.png (10.98 KiB) Viewed 40223 times
