NME308 wrote:Good to hear the issues were only minor!
What carb have you gone with? Is it a custom one from the big names?
Hope to hear more positive news shortly!
I have just started going the complete opposite direction...The carb just cannot handle the compound setup with boost off idle and positive pressure in front of the throttle blades at cruise. I can make it idle and cruise nicely then the AFR's go lean under boost and if I setup the carb to provide fuel under boost it is totally undriveable...
Single turbo like you have there and my blow through carb was a total hoot however! I am sad to be leaving the carb behind.
Ss650 quick fuel carb custom made for the car thanks and yea just minor stuff
la otra 3tc starlet
- mallito1.8
Re: la otra 3tc starlet
