For both of my peanuts with AE86 rear ends, the Celica front Cable is what fit perfectly. The TE21 cable was too short, the AE86 cable was too long. For the rear cables, I'm using two of the same side from the AE86. I can't remember if it's driver or passenger but the part number is BC93880 from Brake Best.maxdout wrote:Rolap,
so which cable did you end up using for the front cable.
TE21/S2000 Swap
Re: TE21/S2000 Swap
"As the excellence of steel is strength, and the excellence of art is beauty, so the excellence of mankind is moral character." - A.W. Tozer
Re: TE21/S2000 Swap
-I had custom E brake cables made here----> http://stores.ebay.com/Bruin-Brake-Cabl ... 7675.l2563
Re: TE21/S2000 Swap
awesome! thanks for sharing the infowhit wrote:-I had custom E brake cables made here----> http://stores.ebay.com/Bruin-Brake-Cabl ... 7675.l2563
Re: TE21/S2000 Swap
that's my buddy jeff's peanut!
i sold him those stretched steelies!
im glad the car went to a good owner!!
Re: TE21/S2000 Swap
Thank you sir!exodus wrote:that's my buddy jeff's peanut!
Re: TE21/S2000 Swap
After much consideration, I decided to go back to my first draft of the transmission mount. I tried to combine the s2000 mount and the TE21 mount but it didn't line up perfectly so I just built the TE21 mount.
- spiceisler
Re: TE21/S2000 Swap
Rolap7 wrote:After much consideration, I decided to go back to my first draft of the transmission mount. I tried to combine the s2000 mount and the TE21 mount but it didn't line up perfectly so I just built the TE21 mount.
Looks original. Great job!
Re: TE21/S2000 Swap
Hi Bryan, I'm not sure which year but the chassis code is KP61. Hope it helps.
Re: TE21/S2000 Swap
Thank you every bit of info helps.Rolap7 wrote:Hi Bryan, I'm not sure which year but the chassis code is KP61. Hope it helps.
Corolla Kid
トヨタ
トヨタ
