Trying to get the best timing on vehicle.  I set the initial timing at 15 degrees (by adjusting my dizzy) at 1000 rpm,  at 3000 rpm my total advance timing is 24 degrees (using timing light with a dial).  A few questions...
1.  Do I need to block the brake booster connection before I do this testing.
2.  Do I need to go higher RPM for total advance timing (like 4000 rpm).
Thanks.
						Total Advance timing 3TC weber DCOE RPM question
