Where to get a good Tach signal
Teun
Post by Teun »
Hi Guys,
Where is the best place to get a good signal for my aftermarket tach?
I've added a pic, could someone point out where to connect the wire?
Thanks!
--=...Lowest BHP title owner...=--
Re: Where to get a good Tach signal
Some ignitors have an extra tach output wire....... most don't has.
You will have to hook the tach to the negative - of the coil.... the green wire on most aftermark tach
Teun
Post by Teun »
thanks, so the right one on the white bar in the pic?
ulises_te72
Post by ulises_te72 »
negative wire of the Ignition coil.
Teun wrote:thanks, so the right one on the white bar in the pic?
No thats still a plus reduced volt
Negative coil
