Clutch for a 3tc with w50 tranny
So Im about to get a w50 already set up for a 3tc. So can I use the 3tc clutch? Is the input shaft splines the same?
ulises_te72
Re: Clutch for a 3tc with w50 tranny
the shaft spines is bigger on the w50 tranny. Here is the lynk for the clutch you need...
http://www.euroexportinc.com/3tc/compet ... 1620c.html
Good Luck
Good Luck
So this will fit the 3tc pressure plate? I have been looking at some kits and they are bigger. This is my last question about it, I know more about engines than clutches and trannys. Thanks man!
ulises_te72
Yes, it will fit the pressure plate and flywheel.
Thank you for that link! It's just what I need for my W58 to 2T/3T gearbox conversion.ulises_te72 wrote:the shaft spines is bigger on the w50 tranny. Here is the lynk for the clutch you need...
Good Luck
Cheers.
njccmd2002
if you dont mind me asking, how was this tranny prepared?
adapter plate? because i have one with adapter plate, and wonder if the shaft would have to be shortened bacause of this...
Nothing here yet, just and empty space... I just wasted 10 seconds of your life when u finish reading this... LOL
nope but they have told me to weld the 3tc bellhousing to the trans so it has more room to hold on too but I used the adapter plate and that clutch it works well just do a normal break in and your set
