1980 corolla 2dr turbo 3tc efi aka "banana boat"
toyotero2dend
Re: 1980 corolla 2dr turbo 3tc efi aka "banana boat"
Post by toyotero2dend » Tue Dec 10, 2013 11:31 pm
sounds to me like it has a weak spark or timing is off Carlos
Alexason
Post by Alexason » Wed Dec 11, 2013 9:06 am
Efi is a headache but you'll get it. Can you confirm that the vr sensor is 9 teeth before the missing tooth when the motor is tdc?
hemilove
Post by hemilove » Wed Dec 11, 2013 3:28 pm
The spark is good its blue and the only thing I can pin on it is that the ground on the coil itself is not sting enough but that's it and as far as nine teeth @ tdc I have to check but I will do that this weekend and keep yall posted thanks guys as far as what ever else you see please let me know thanks
hemilove
Post by hemilove » Sat Dec 14, 2013 4:00 pm
BOBLOOK wrote:How strong is the spark are they firing all? It look like an timing issue spark !
That amount of fuel in cold start can be normal
Is those spark plug iridium ?
Wat coil are you running
Its the ford edis 4 coil from a 1993 escort
Post by Toyota1515 » Sat Dec 14, 2013 4:30 pm
What ecu are u using Mega Squirt?
hemilove
Post by hemilove » Sun Dec 15, 2013 3:30 pm
Its a megasquirt 2 v3.0
Post by Toyota1515 » Sun Dec 15, 2013 6:10 pm
Sorry for you,
When u finish setting it up and havit dial it in u have spent as much or more in $ time and effort than buying a microtech a halltech or a fueltech, and with a lot more headaches!
Post by BOBLOOK » Sun Dec 15, 2013 8:44 pm
Try to disconnect the fuel pump or fuel supply clean the spark plugs let them dry and use carb cleaner in the intake see what it does. Be carefully for backfiring.
If engine prone to start you will know that system is getting to much fuel :lol: :lol:
hemilove
Post by hemilove » Mon Dec 16, 2013 5:16 am
Ok I am willing to try it but the only issue is that all the dtuff is new and needs to be broken in what do yall do as far as efi break in and tune on a fresh. Engine
Post by BOBLOOK » Thu Dec 19, 2013 8:34 pm
It shouldnt harm the start is only to sort out the problem you have ;)
