need help with te72
need help with te72
cant seem to get this car started. i have a 1989 te72 coupe. the wiring in this car is terrible and looks like helen keller did it. if u need lics i can get you some. i tried to rewire the car using the diagram but that shit sucks and im not the greatest at wiring. so if anyone can tell me what wires need to go where to get it running i'll be happy
Re: need help with te72
Are you sure youre using the correct diagram since you list 1989 te72 coupe am not familiar with that yearque wrote:cant seem to get this car started. i have a 1989 te72 coupe.
**** i meant 1980 sorry im on my iphone
What many people most time do when they have electrical problem prior to fix do unknown the mess it up even more.
Don't ask me way !
You may start fix back the changes you made !
Does the engine turn....... 12v to the heavy starter and relays 12v when switch is cranking you can use a voltage meter or tester to check this.
Here a few basics steps to check for the starter and ignition power source
Check this and post what you find
