removing msd
point8rolla
removing msd
Hello people I'm new but a recently brought a 79 corolla with a built 3tc drove a couple and now it won't start . I found that the problem is the msd 6al. Now I want to go back to stock ignition system but there seems to be a plug missing right now that plug is run to the msd to bottom of the distributer but theres no way or no plug coming from the stock wire harness to go back to stock any help we be greatly appreciated thanks
Re: removing msd
The missing plug might be the igniter plug as for msd use you can remove the igniter. You might need the igniter to make it work again ! Here the diagram ! You can get another msd on ebay for cheap.
- Attachments
- ignition.jpg (20.41 KiB) Viewed 13300 times
point8rolla
Re: removing msd
Thanks a lot for the response! I priced the ignition module and igniter and it may be cheaper to stay with the mad.....
Re: removing msd
I guess the samepoint8rolla wrote:Thanks a lot for the response! I priced the ignition module and igniter and it may be cheaper to stay with the mad.....
point8rolla
Re: removing msd
Found a msd for 90$ I'll put it on tomorrow I'll let you know if it all goes gd
point8rolla
Re: removing msd
Just to give a lil info on the car it has 3tc bored to 2.0 flat vavles double valve springs 304 cam head cut 45 45 mmwebber eagle rods
Re: removing msd
Stock ignition would had have effect on the performance
point8rolla wrote:Just to give a lil info on the car it has 3tc bored to 2.0 flat vavles double valve springs 304 cam head cut 45 45 mmwebber eagle rods
point8rolla
Re: removing msd
Car is running again it was the mad
Re: removing msd
Awesome show use some picture ?
point8rolla wrote:Car is running again it was the mad
