And I read somewhere that I can use a flywheel and a pressure plate from a t40, and then the clutch plate from the w58, is this right?
Thanks for helping a brother out.
island chain sells an adapter plate, your going to need to buy the correct clutch disk and redue your youk on the drive shaft...deaconfrost wrote:and by parts I mean anything other than the obvious components of the drive train, I am going to be pulling it from a donor this upcoming week
I was looking at getting a custom one piece driveshaft made, this would solve the yoke issue correct? and I did message him about the adaptor plate, just waiting on a response (hopefully it comes soon haha)island chain sells an adapter plate, your going to need to buy the correct clutch disk and redue your youk on the drive shaft...
If auto yes, manual no. If I were going to spend the money on a one pc. driveshaft, I would get an older type with the serviceable u joints. If you plan on changing the rear, I would do that first also. Thats going to be the weak link even with a T50. I took measurements off mid 80's 2wd toyota trucks and looks like would be direct bolt up to leafs on a wagon, same width drum to drum, but 5 bolt lug pattern.deaconfrost wrote:I was looking at getting a custom one piece driveshaft made, this would solve the yoke issue correct? and I did message him about the adaptor plate, just waiting on a response (hopefully it comes soon haha)
