Not recommended.
Show youre Ghetto fixs
Rearend whining entire banana or two in the diff quit noise
Not recommended.
Not recommended.
Re: Show youre Ghetto fixs
Whenever you radiator leak for some reason and you don't have access to stock leak and you need to travel
Add an egg and let it run for a few min it will stop
Add Corn flour it will stop
Note those are only temporally fix
We use to add a little gearoil in the engine motor oil mix it whenever the engine bearing start knocking
Don't do this
Don't do this
Oh shimming the main and rods bearing with lowtech paper
http://deckwartaperedshims.com/main-bea ... lation.php
Don't recommend this
wd40 for intake leaks.
atf to loosen the carbination on the rings wear a smoke mask.
Ahaha hella funny i unsized a 350 motor wit ATF and it works but it smoked for days but it workedhemilove wrote:wd40 for intake leaks.
