MSD instalation guide
Here is the msd guide bible !
For or corolla installation look add pdf file page 28 ;)
http://www.msdignition.com/uploadedFile ... pn9615.pdf
TOYOTA_LOVER
Re: MSD instalation guide
Post by TOYOTA_LOVER »
I have a 6a hooked up to my 3tc and I get no spark. It ran fine before doing msd upgrade msd box gets power (cuz power light turns on) I have the purple n green wires ran right to dist. not using white wire n gray is to the tach. Any ideas on why no start
Use the white wire on a previous install the green purple failed after installation
TOYOTA_LOVER
So connect the white to pos+ of dist. then what to do about no power to coil
TOYOTA_LOVER wrote:So connect the white to pos+ of dist. then what to do about no power to coil
You need to hook only the black and orange on the coil
The msd will take care of the coil power itself ;)
TOYOTA_LOVER
I get no power to coil from msd only power out I get is from white :?: think it is bad msd box I really do THANK YOU FOR YOUR HELP
TOYOTA_LOVER wrote:I get no power to coil from msd only power out I get is from white :?: think it is bad msd box I really do THANK YOU FOR YOUR HELP
When you said no power to the coil do you mean no 12V ??
Did you crank the engine to check for spark usually those msd don't burn so easy ?
Can you post the installation picture the way you wired ??
TOYOTA_LOVER
I have from msd box heavy red to bat. heavy black to chassis ground orange /black to coil grey to tach green/purple to distributer white wire not used but gives power out and red ignition The box turns on as seen by the power light. car cranks no spark u said use white wire to where?????
Admin
Site Admin
Post by Admin »
Heavy red = Plus +
Heavy black = ground
Red = 12v ignition switched
Orange = plus + coil positive
Back = negative coil
The tach wire goes to the input of the msd
Check it the msd is set for 4 cylinder
The green and purple is for the magnetic pickup distributer !
Or The white wire to the negative of the distributer
gotae86
Post by gotae86 »
How do you tell which style distributor you have?
