having auto trans fitting issues
				Supacold87
i just mated a used a40 from a salvage yard to my 82 3tc but after puting it in the car i noticed a scraping sound when i turned the crank and flywheel to install the torque converter bolts, so i removed the starter which caused the scraping sound but i also noticed the flexplste was too far from the torque conveter to get a bolt on it. so my question is are there different starters, torque converters, and or flexplates for this trans mission or is the flexplate just bent or something.
				Supacold87
Re: having auto trans fitting issues
Well after due diligence I finally figured out what I believe to be the issue I'll know for sure Monday
