te31 complete grill in good shape 80$
te31 tail lights in ok shape one of the trims has crack on it and light has a scraths 40$ for both
te31 driver mirror 40$ toyota one
te72 dash trim 15$
te72 e brake cover 20$
te72 wagon rear vents 40$ for both
te72 door pullers only 3 all for 35$
3tc dipstick power steering style 25$
3t have a few of them stock cam each 40$ has surface rust
2t 3t carb was working when pulled off 50$
2t flywheel pressure plate and clutch lot of life on it off a 75 rolla 150$ come with flywheel bolts
3tc flywheels with unknown brand aftermarket clutch and plate 160$ come with flywheel bolts
te72 trans mount 60$
te31 trans mount 60$
te27 trans mount 100$
3tc crank pulley complete with ac pulleys 80$
3tc crank pulley 40$
2t crank pulley small one 60$
2t fan pulleys 40$
2t fanclutch pulleys 25$
rocker assembly 60$ the one with the collar stoppers one is broken
