Transmission questions
1300cctuner
I have a 81 Corolla 3tc t50 trans and trans siezed up on m e. Found a t50 from a 83. Swapped the guts and tail shaft into 81 3tc casing. Out put shaft was a 20 spline and now the 83 is 22 spline now. Does anyone know where to get a new yoke and would i be able to just swap it on my old driveshaft with new u joint? I can only assume the length should be the same as far as driveshafts go right?
Re: Transmission questions
Go to the Toyota dealer parts department and at least see what the correct part number and availability for this item is and then you stand a better chance of someone being able to locate one for you.1300cctuner wrote:I have a 81 Corolla 3tc t50 trans and trans siezed up on m e. Found a t50 from a 83. Swapped the guts and tail shaft into 81 3tc casing. Out put shaft was a 20 spline and now the 83 is 22 spline now. Does anyone know where to get a new yoke and would i be able to just swap it on my old driveshaft with new u joint? I can only assume the length should be the same as far as driveshafts go right?
If you were in SoCal I would be able to suggest parts yards where you stand a small chance of finding the correct Driveshaft Yoke. Place your location under your screen name please. Thanks
bigmikesocal
Hello,1300cctuner wrote: Mon Sep 03, 2018 2:03 pm I have a 81 Corolla 3tc t50 trans and trans siezed up on m e. Found a t50 from a 83. Swapped the guts and tail shaft into 81 3tc casing. Out put shaft was a 20 spline and now the 83 is 22 spline now. Does anyone know where to get a new yoke and would i be able to just swap it on my old driveshaft with new u joint? I can only assume the length should be the same as far as driveshafts go right?
Would you still happen to have the 20 spline driveshaft slip yolk? I would like to purchase it. Been looking for one. One of my T50 has a 20 spline output shaft.
Thanks,
Big Mike
